Monday CRM has a great native feature that allows users to “set label change conditions” for any status column, basically allowing you to create rules/required columns that users must complete before an item or subitem’s status can be changed. This is a great control to force users to enter all the required information.
As far as I can tell, this feature does not exist in Monday Work Management (WM)…just in the CRM product. The only way I can find to set label change conditions in WM is through third-party apps, which cost additional fees.
This feels like a critical function to maintain data integrity…and it’s already available on CRM. Would be amazing if we could see this in WM soon.
Thanks!
