Create a Project board from Template Using Workflow Center?
Hello Everyone,
I am working on a Portfolio Solution that creates a project from template into a specific folder. The selection criteria, in which folder project would be created, depends upon 2 statuses. If those 2 match, project should be created in that folder.
Now I am stuck at:
  1. If I use automation with built in recipe from Portfolio Integration, I can create a project from template, but it allows to check for only 1 status out 2 I need and I cannot modify this recipe.
  2. If I opt to go with Workflow center, I can check for both conditions, but there, I don’t see an option to create a project from template.
How can I achieve this using Monday.com native tools? Using third party tools is out of scope.
Cheers!
Has there been any updates on this? Any chance there are updates coming to Workflows to allow creating boards from Templates?
And any plans for blocks to edit data within a newly created board (basically dynamic board selection within blocks)?
Nothing yet. I am still waiting and there is no update. I went through monday labs as well and there is nothing of this sort being worked upon.
